Hi,
I have got the bypass done and it seems like everything works okay; however, as soon as I start driving the screen stops playing/gps options go away... is there any firmware I need to upgrade or does anyone know how to fix this problem?
Hi,
Your pin that you moved is not connected.
Redo that.
^ bingo.
If the pin is moved to the correct location and is seated in the harness correctly, and those two wires are grounded properly, the bypass will always work, 100% guaranteed.
