drober30 said:
I ran out and bought a second AVIC Z1 with an April date when it was determined that the July units could not be bypassed.
Sorry about that. I don't know if it was determined that they could not be bypassed. We did know they couldn't be bypassed with my circuit... it just took a little time to figure out what it took for the new July units.
drober30 said:
Now that the July units can be bypassed in an even easier fashion (just grounding a wire) I wonder what unit would be better, April/July?
Actually it's grounding 2 wires.
http://www.sminntech.com/z1flash.html
What would be better? I would say that the July 06 unit bypass is "better". There are a couple things that would constitute as "better".
1. What is bypassed?
2. What is more reliable?
Well the stuff that is bypassed is exactly the same on both. It's not like 1/2 the stuff is bypassed with one while everything is bypassed with the other. The end result of the bypassing results in the same exact unit.
So we are only left with "better" referring to what is more reliable. And I would have to say that the new bypass with grounding the 2 wires is more reliable. Not cause I have no confidence in my circuits, but because they have processors, software, and a dozen components. All this to make it as easy as possible to install. Every single part has a failure rate and a possibility of failure. I tried to minimize this as much as possible when I designed it, but the fact remains all those parts have more of a possibility of failure (how ever remote) than 2 wires do.
So better? I would have to say that the new July units are better.
drober30 said:
The pre July units could be disabled with a software upgrade?
It's possible, any thing is possible. I don't know what "features" or components of the Z1 can be updated with a software upgrade. I can't say for sure what can and can not be upgraded with the Z1.
drober30 said:
The post July units are bypassed physically and have a less of a chance being affected with a software upgrade?
What are your thoughts on this?
I can tell you one thing though. If the Pre-July units (headlight flasher) bypass can be disabled with a software update then so can the July 06 (ground 2 wires). Both of these were put in on purpose. They took out the headlight flashing software and put in the 2 wire grounded check. They can make a change going forward.
My belief is that the software upgrades is for the hard drive, not flashing the micro on the fly while the unit is installed. This bypass is handled by the unit not the software in the hard drive, I think that is just data. So I am guessing that neither will be "updated" away. But that's just my thoughts with no real knowledge on how the Z1 is engineered or what the engineers at Pioneer have up their sleve over the next few years.
