Need help with btb200 install
By crhatch02 · Aug 16, 2008in Problems/Troubleshooting💬 14 posts👁️ 2,805 views
Posted Aug 16, 2008 · 00:55 UTC#1
alright I have the unit hooked up to my avic d3...but when I get my phone hooked up to it(htc mogul) it doesnt give me any kind of options..It will notice my phone and i will be able to accept calls...but there is no function menu to choose...it also wont let me make calls from my d3 just accept. The only button I can push on the screen is "Voice"...........but the function menu will work with my bluetooth audio...I get a connection open dissconect and device info to choose from with the BT Audio Menu........
And if I make a call with my phone it will pick it up in the d3 and I will be able to use it then.
I NEED HELP
Posted Aug 16, 2008 · 02:16 UTC#2
after u pair the unit register it and you will get all the features
Posted Aug 16, 2008 · 02:22 UTC#3
he said the phone can accept calls so it is paired and connected..
do you have the unit bypassed??
Posted Aug 16, 2008 · 02:28 UTC#4
nope...its not bypassed
Posted Aug 16, 2008 · 02:31 UTC#5
theres your problem. phone options like that can only be done if the parking brake is up (if you tapped the wire to it) or if you bypass it. its a safety feature pioneer added
Posted Aug 16, 2008 · 02:35 UTC#6
well when Im tryin all this out, my car is parked with the ebrake up..
Posted Aug 16, 2008 · 02:37 UTC#7
well did you tap the parking brake wire from the unit to the OEM parking brake wire?
Posted Aug 16, 2008 · 02:40 UTC#8
nope...I havent done anything to the harness...except hook it up my my existing harness......Im assuming I havent read up on it enough
Posted Aug 16, 2008 · 02:47 UTC#9
no, you just didnt hook it up to the parking brake or bypass it..how do you expect it to know the parking brake is up if the unit's not connected to it?
anyways, since you have to take the unit out to do either of the 2, id just bypass it...you'll be glad you did when you have to make a phone call while driving lol. to do the bypass:
take the mute wire (its the black and yellow wire on the connectors with the RCA's) and pull the wire out of its slot, and relocate it to the empty slot directly below it. then you ground that wire and the parking brake wire (light green wire on the main connector) and it will be bypassed. then you can also watch movies and do nav functions while driving as well.
PS: just be careful when pulling it out, its locked in, so use a small sharp object to release the lock (i use a pocket knife)
Posted Aug 16, 2008 · 02:55 UTC#10
that might be my problem....I dont have the harness for all the rca's...i just have the main harness
Posted Aug 16, 2008 · 02:59 UTC#11
then your 2 options are to either get that rca harness or just connect the parking brake wire to your parking brake. personallly i think getting the rca harness is the better option, besides the ability to bypass, if you ever decide to later sell it, your chances of someone buying it without all the connectors is not very likely.
Posted Aug 16, 2008 · 03:06 UTC#12
hmmmmm..ok.Thanks for all the help
Posted Sep 08, 2013 · 00:08 UTC#13
Sorry for bringing up this old thread but I have a question with the bypass.  I already have bypass my stereo to watch dvd on the go but now I just got the BTB200... does this has to be bypass as well? If so, when I got my btb200 unit from a seller it has 3 wires (red,black and yellow) and the stock pioneer wire is yellow and black.  How can I do this?
I circled with a cyan color over the 3 wires from the btb200 on the right and the two circled on the left is from the harness to the avhp4200.  Also I'd like to add there is no fuse connected to the yellow wire (the stock has a built in fuse holder) is it ok to tap it in without the fuse?  Thanks!
Edited Sep 08, 2013 by EclipseAVH
Posted Sep 08, 2013 · 04:28 UTC#14
There is also a red wire on the head unit harness.
