NAV problem with time remaining
By dreamer728 · Aug 16, 2008in Problems/Troubleshooting💬 3 posts👁️ 594 views
Posted Aug 16, 2008 · 03:02 UTC#1
We took my car with the AVIC-D# unit from New Hampshire to Virginia and back - about 1:44 away from home, the time remaining counter stopped counting down.
Now, when I enter a route, it has astronomical times calculated - like 5 hours to go the 10 miles between work and home, etc...
Anyone else experienced this? Or did I break "Sheila"? (yes we named the nav voice)
Posted Aug 23, 2008 · 21:42 UTC#2
i was having the same problem... for a trip that would normally take an hour it was saying 6. the directions were still right on, nav worked perfectly. i dealt with it, then when i had to take the unit out to put in my bluetooth, i reset the unit after i unplugged all the harnesses. this fixed it. if you do not want to take the d3 out of the dash, try the little reset button(use a small pointed object on the little button next to eject)
Posted Aug 23, 2008 · 22:08 UTC#3
Go to SETTINGS MENU > SYSTEM OPTIONS > AVERAGE SPEED
You can set the average speed for minor roads, major roads and highways. If these settings have somehow been set to a very low speed, the estimated time of the route will be way longer that it should be because the nav uses the speeds set on that page to calculate how long a route will take.
