I just upgraded from the Z1 to Z3 hard drive. I had Ducatiboys flasher bypas on my Z1, and it worked flawlessly. After upgrading the drive to Z3, everything worked fine.... except that my flasher bypass doesn't work anymore.... which I was told that when I bought the new drive.
I went in and did the 2-Wire bypass myself.....probably should have disconnected the ducatiboy flasher bypass.... but I decided to just leave it on there. After I finished the 2-wire bypass, everything seems to work fine except:
1) My Rear view camera doesn't work anymore. It did work after I installed the Z3 drive, and before I did the 2-wire bypass
2) In Map Settings, and under View Mode.... 3 options are grayed out.... Guide Mode, Route View adn Rear View are all grayed out
My first guess is that I need to remove the flasher bypass....... but I was hoping there might be an easier fix ??? I would appreciate any thoughts/insight that you guys might have!
