Okay, this is my first post, although been reading on the site alot and you guys seem super knowledgeable! In any case, I did a quick search and theres just so much info and problems through the threads that none in the recent pages helped me arrive at a solution.
I recently bought the BTB200 and installed it in my car to which I thought no problems. I installed it with the yellow wire which is what I read somewhere it should be installed. Everything worked perfect with my iPhone with the exception of the phonebook which I understand isnt possible. Then a couple days later, my battery died. Now I am turning to the experts...
Should the unit be installed to the ignition wire so the unit only turns on when the car turns on? I ask because I recharged the battery, re-spliced into the red wire, and now it deletes my phone from the registered list and resets almost the entire bluetooth unit when I turn on the car.
Any and all help is greatly appreciated, I guess I'm just lost because either coincidence that my 3 yr old batter finally pooped out on me or the correct wire doesnt function as accurately.
Thanks for reading my babble...ha ha ![]()
