I'm about to install the F90BT and the boyo backup camera. I want to know how would one wire up the backup camera? Do you do the following steps?
1. Install the camera at your desired location
2. Run the wires to the headunit with the RCA input
3. The + and - can be connected to the headunit's harness
4. Connect the reverse wire from the headunit to the car's reverse wire?
By following these steps, will I be able to see the camera when it is in reverse and at anytime I want to see the back of my car?
