If i ground my parking brake wire in my N2 what do I achieve until i do the bypass mod, and does anyone have a picture of the n2 board where i have to use a circuit writer to connect
You won't accomplish anything. The parking brake has to ground after the unit boots otherwise everything that is normally locked out will stay locked out. If you hook it to a switch, you'll be able to use the nav functions, and watch movies until the car starts moving over a certain speed.
so the system has to boot with the parking brake wire wired normally then you can ground it to get nav functions while driving? what about the solder bypass can you do that before the unit boots because i havent installed the unit yet but needed to know whether or not you could do it before the unit is installed?
