Wiring issue
By jeep06 · Aug 31, 2006in Problems/Troubleshooting💬 7 posts👁️ 1,542 views
Posted Aug 31, 2006 · 01:49 UTC#1
i have my ACC wire spliced to my cig. lighter that turns on with the car because the ACC wire from my d2 will not work with the wiring harness.
so now everytime i turn on the a/c fan switch(powers up a/c) the navigation powers off. (i believe both the cig. lighter and a/c both connect into the same harness but i am not sure on that
did i make a bad connection or something else?
thanks
Posted Aug 31, 2006 · 01:56 UTC#2
Sounds like it might be a bad connection. Have you tried plugging something into the cig plug and seeing if that turns off when you turn on the ac? If it doesn't then you definately have a bad connection.
Posted Aug 31, 2006 · 02:05 UTC#3
yes when i plugg sumthin into the cig lighter and turn on the a/c it still works...
so i have the ACC wire spliced into the cig. lighter wire. is there anyother way..
Posted Aug 31, 2006 · 02:15 UTC#4
Yeah, to be honest your best bet is going to be break down and pick up the chrysler databus interface.
http://peripheralelectronics.com/web/onstar.asp
It's the chyah05 on that page. It also gives you the vss wire too. Got to use one of these the other day in a new dodge makes life a lot easier. As for your reverse wire. Here go
Reverse Lights WHITE/LT.GREEN (+) IPM, CONN2 PIN 2
The IPM (Integrated Power Module) is on the driver fender, behind the battery.
Anything else ya need?
Posted Aug 31, 2006 · 02:53 UTC#5
no ithink that covers it
thank you it was a big help
and i liek the fiberglassed dash i got a 10inch monitor firberglassed into my mountaineer.
Posted Aug 31, 2006 · 03:09 UTC#6
Cool. Thanks. Got some pics of the moutaineer, or your jeep? Love seeing custom work.
