So I have my speed sensor lead connected into my PCM. Looks like 4 pulses per 1 mph. The AVIC works great.
BUT
At low speed between 0-11 mph the car's PCM registers no speed signal at all or intermittent. The AVIC D3 registers the speed correctly.
This is causing issues with the speed sensitive power steering and the CEL below as a result.
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent -PCM
I can have the wire tapped in at the PCM connector and I have it soldered in. Am I missing something here. For the time being I have decided to unhook the speed wire on my AVIC-D3 and the PCM registers the correct speed between 0-11mph now.
Any ideas?
