Z2 Bypass
By legendbliss · Aug 20, 2008in Hacks/Mods💬 4 posts👁️ 1,643 views
Posted Aug 20, 2008 · 22:56 UTC#1
Hey guys! i have my Z2 coming in on friday, and i have a few questions.
Will i have you update the unit with the 34mb file in the sticky thread?
and also, i read through the whole thread and found different answers, can someone answer me clearly.
i read that you have to remove the yellow/black wire and move it to the slot right above it, and ground that wire, how would i do that? and also ground the parking brake wire.
next, i read that you can ground the parking brake wire and add a wire into an empty slot on the harness and ground it.
i did click the link on the 2wire bypass page but it still doesnt make sense to me.
HELP PLEASE!
Posted Aug 20, 2008 · 22:59 UTC#2
the answer is "you might" need to run the update CD
as for the wiring of the bypass, reread the instructions.
Posted Aug 20, 2008 · 23:01 UTC#3
i did read the bypass. it says to ground the parking brake and add a wire into the harness and ground it..
Posted Aug 21, 2008 · 01:13 UTC#4
That is correct.
