POIS Speed Cameras
By ceramicax · Aug 31, 2006in Hacks/Mods💬 13 posts👁️ 3,809 views
Posted Aug 31, 2006 · 08:38 UTC#1
Hi!! First at all excuseme for my english.
that's my first post at the forum, congratulations for the work.
I've AVIC-HD1BT that is the european model of AVIC Z1, and
previously i had the AVIC X1/R, when I had the X1R i can load
POI's of Speed Cameras from a CDROM (folder POINTS) and it was saved at the AVIC (300 max). Now I've mounted HD1BT with CD-IB100 for Ipod and DVB-T from Pioneer also, but now I'm looking the way for saving poi's for HD1BT or Z1.
Anyone can help me? thanks
Posted Aug 31, 2006 · 14:09 UTC#2
Set them as waypoints and add a sound to be associated. When you approach the waypoint the sound will play
Posted Aug 31, 2006 · 14:51 UTC#3
I think he wants them loaded so they are there all the time, not just on one trip. Icons on the map that just show up like gas stations and what not.
But I don't think the Z1 has this ability (at least not in the US).
Posted Aug 31, 2006 · 15:23 UTC#4
Posted Aug 31, 2006 · 16:58 UTC#5
I think crazy means set them as address book locations. If you do this they will stay permanent and always be on your map. I haven't played around with it but it sounds like if you set a sound it will make a sound when you are nearing one? Either way they will always be on your overhead map.
Posted Aug 31, 2006 · 20:50 UTC#6
Yeah but you could never load them all into the Address Book, and it would have to be manual. Most purpose-built GPS's have the ability to load customer POIs (my Garmin did). Many services sell a database of the camera locations in the correct format for the mainstream GPS's for this reason. You buy an annual subscription and they keep updating the database.
Posted Sep 01, 2006 · 07:16 UTC#7
Yes ducatiboy
Posted Sep 01, 2006 · 07:17 UTC#8
yes crazy4life that's exactly what AVIC X1R did.
Posted Sep 01, 2006 · 07:20 UTC#9
If you are interesed about working at this theme i can upload a file like AVIC X1R used.
Posted Sep 05, 2006 · 16:27 UTC#10
You can buy the Speed Camera POI update from TeleAtlas, it is not supplied by Pioneer. Obviously I have never used this, so I don't know how accurate or even how it works, but it says it is for the AVIC-HD1BT.
Linky:
http://www.navshop.com/en/category/clar ... 1bt/69/0/0
Posted Sep 05, 2006 · 18:38 UTC#11
Yes but..... why pay???
Posted Sep 05, 2006 · 18:46 UTC#12
cause if you don't, you won't have it.
Posted Sep 06, 2006 · 07:01 UTC#13
MitchellStang I'm sure is possible doing it, only it'll cost a little of work
