F900 map POIs?
By cigga24 · Aug 22, 2008in General💬 8 posts👁️ 1,565 views
Posted Aug 22, 2008 · 02:35 UTC#1
Does anyone elses map shows gas station icons?
I have my MSN trial still going on if that means anything. Anyway on my map gas stations icons are everywhere. I just noticed someone elses on here has food icons. Is there a way to get certain icons to show up or not at all or all of them. It was weird zooming out to country view and seeing the map completely full of gas stations. They dont show up in the world image though :roll:
Posted Aug 22, 2008 · 06:10 UTC#2
Its called Overlay POI
Posted Aug 22, 2008 · 10:29 UTC#3
Actually its called MANAGE POI under the NAVI SETTINGS, VISUAL tab. It does allow you to hide or show the POI icons. It will allow you to turn them off or show them only at a certain distance from your current point. Page 130 in the manual if you want detail info.
Posted Aug 22, 2008 · 19:11 UTC#4
Oops, was thinking of my old avics
Posted Sep 02, 2008 · 19:34 UTC#5
I went through my setting for gas stations and msn direct and changed view mode to "off" and they still show up :evil: these things will not go away. All other icons will come off and on except gas. This is soooooo annoying.
Posted Sep 10, 2008 · 16:09 UTC#6
I emailed tech support and they are aware of this but have not found a solution yet.
Posted Sep 10, 2008 · 19:22 UTC#7
I have the same problem with medical facilities, and there is a billion of them.. I even reset my unit to factory defaults but the POI's still appear.
Posted Sep 19, 2008 · 04:01 UTC#8
I had the same issue with the medical facilities, but I seem to have fixed it.
Problem:
All I wanted was to have Hospital icons show up (just in case), but I was getting everything. I went into Manage POIs, and everything I turned of was turned back on after every reboot.
Solution: (Worked today, I'll have to eat crow if I wake up and it doesn't work)
In Manage POI, Edit the Medical Group, and turn it off (Set POI Visibility Distance on Map = Off)
Edit each Medical subgroup, set the distance as you want it or off completely
Hope that works.
