Is it possible?
By NickyD32 · Aug 22, 2008in Hacks/Mods💬 14 posts👁️ 2,724 views
Posted Aug 22, 2008 · 05:35 UTC#1
Is it possible for anyone, namely stephanie, to upload their entire file system, without the nav boxes or key beeps, to a .zip which i can then unzip, put onto an SD, and put on my 900? im nervous to do it myself...
if you could, it would be GREATLY appreciated.
Posted Aug 22, 2008 · 05:37 UTC#2
also, is it possible to get rid of the "system startup" box???? is stephanie can give me all of the above, i'd be the happiest dude ever.
Posted Aug 22, 2008 · 06:10 UTC#3
That would be a pretty large file...
Posted Aug 22, 2008 · 06:25 UTC#4
yeah i know, and id definitely be willing to do all this stuff myself, but i dont think i can get the testmode deal since i got a unit with the new firmware... or am i mistaken? i've been reading posts all day and im horribly confused.
Posted Aug 22, 2008 · 06:35 UTC#5
The contents of the flash disk is 1.64 gigabytes... FYI.
Posted Aug 22, 2008 · 08:46 UTC#6
Not so large.
Posted Aug 22, 2008 · 10:20 UTC#7
The test mode files are available at the thread below. About halfway down, download the file that says testmode.zip
http://www.avic411.com/forum/viewtopic. ... c&start=30
Posted Aug 22, 2008 · 10:52 UTC#8
if needed, i can host those files... got a couple gigs free disk spaceon my web box
Posted Aug 22, 2008 · 11:12 UTC#9
If you could, it would be greatly appreciated.
Posted Aug 22, 2008 · 12:00 UTC#10
I'm not sure you'd want to replace the file system of an F900 with that of an F700. You might lose some functionality.
I do have a modified-and-tested data.zip file on my server that you can download, then you just need to use the testmode hack to copy it onto your own nav unit. You can grab the data.zip here:
http://www.felesmagus.com/stuff/data.zip
Posted Aug 25, 2008 · 07:21 UTC#11
yeah an already customized code to remove certain settings in a nice little package thats already programmed and just needs to be uploaded to the unit would be nice.
like a replaced font, custom main menu banner like Stephanie has
and the removal of the bootup message and change the color of the clock
It'd be nice to have pre-programmed zip files that way a novice (like myself) wouldn't do something stupid and screw up the unit by changing something accidently.
like could have like 3 different pre-set packages or whatever for the more requested hacks. kinda like an a-la-carte download LOL
Awesome work on the hacks Stephanie! looks awesome!
Posted Aug 25, 2008 · 15:58 UTC#12
Stephanie, did that have the sounds removed? I didn't think you'd updated in that release.
Posted Aug 25, 2008 · 16:14 UTC#13
The AV keybeep sounds are a separate issue and don't live in the data.zip file. See the other thread about removing the keybeeps.
Posted Aug 26, 2008 · 01:08 UTC#14
Back to someone offering space earlier, I have a collocated server and have ample room for any downloads
[root@sarge] /root > df -h
Filesystem     Size    Used   Avail Capacity  Mounted on
/dev/ad0s1a     73G     13G     54G    19%    /
