Genre Names
By fm606713 · Aug 22, 2008in General💬 9 posts👁️ 965 views
Posted Aug 22, 2008 · 14:23 UTC#1
Is there any way to change the genre names on the Z2?
Posted Aug 22, 2008 · 14:45 UTC#2
you hafta make all your changes before you record the cd.
Posted Aug 22, 2008 · 15:07 UTC#3
Thanks for the response. But I just bought and installed a refurb unit. (It works great by the way.) And there are ten or so strange genre names already in the Z2 unit, only two of which I want to keep. Can I change the genre playlist names already in the Z2?
Posted Aug 22, 2008 · 15:22 UTC#4
Not that I know of. what i would suggest is write those songs down, completely erase the HDD, download those songs, and start over organizing everything yourself.
Posted Aug 23, 2008 · 01:03 UTC#5
How does one erase the HDD? I spent most of the afternoon/evening deleting playlists, editing ID3 tags, writing CD R's, etc. and each time I load a CD on to the Z2, I get these screwy genre names. None of the genre names I entered into the ID3 tags appear on the Z2. I suspect I am not properly erasing the HDD. What i am doing to erase the HDD is deleting all of the albums from the playlists. Is that all there is to erasing the HDD? I think that there is some area on the HDD that is not being erased and it is setting the genre names each time I load a CD R. Consequently, all of the tunes I load are being places in the "Other" genre.
Posted Aug 23, 2008 · 02:15 UTC#6
its in the manual somewhere, i remember when i bought myne used, the previous owner had Soulja Boy on it and i went crazy tryin to restore it (I hate Soulja Boy). eventually i found it in the manual
Posted Aug 23, 2008 · 22:31 UTC#7
Found how to erase the HDD. Did it and still I get the same wierd genre names. I am about to give up. :shock: Thanks for the help so far, anyone have any further ideas?
Posted Aug 24, 2008 · 00:26 UTC#8
You can't enter in your own Genres (like when you are entering the ID tags before burning your CD).
You can only select Genres from the pre-selected list only the Z1-Z3's list of genres.
So you have to assign each individual track with the genre available on the Z3's list only.
Posted Aug 27, 2008 · 19:29 UTC#9
What happens if you burn a CD using CD-Text to include ID3 information and you use a Genre that isn't on the list? Will it add the new Genre to the list on your Avic, or will it assign the song to a different Genre that is already included?
For example, burn a CD with a bunch of Country songs with the CD-Text info burned to the disk. Will the Avic add the Country genre to it's list, or do something else?
