think im screwed
By chetmaro · Aug 23, 2008in General💬 11 posts👁️ 1,864 views
Posted Aug 23, 2008 · 02:43 UTC#1
I had a friend trying to help me install my d3 and he spliced into the power for the cig lighter instead of the power for the radio harness. This popped the fuse on the back of the nav unit but there was a puff of smoke first. Now the unit keeps popping fuses, my guess is that it shorted something internally and that’s why we keep loosing fuses now. Does this sound about right? Can this be fixed or is the unit toast?
Posted Aug 23, 2008 · 13:07 UTC#2
run the power from the harness. also check to see if the ground is good. re connect the ignition and power wires. normally fuses pop from direct grounds. if this doesnt work, you probably have a bigger issue....its worth a try to re wire those wires though....what type of vehicle is it? because some you need to run your own power wire
Posted Aug 23, 2008 · 13:18 UTC#3
its a 94 NSX, im going to mess around with it a little bit today but im not keeping my hopes up, I just hope ill be able to have it repaired
Posted Aug 23, 2008 · 19:05 UTC#4
kick ur friends ass lmao
kidding
Posted Aug 23, 2008 · 20:29 UTC#5
lol he ment well, just looks like its gonna cost me some money
Posted Aug 23, 2008 · 20:56 UTC#6
if it keeps blowing fuses there is an internal issue, probably a diode blown. question is what wire did your friend tie into on the cig lighter? sounds like he may have tied the ground to a power line, if he had tied power to power even at the cig lighter this would not have blown a fuse or smoked the unit. where did you get the unit from? if your friend did indeed tie power to power and ground to ground then you may be able to take the unit back for an exchange.
Posted Aug 24, 2008 · 00:11 UTC#7
take it to a shop and have them test your radio, althow it sounds like you might be shipping it.
Posted Aug 24, 2008 · 16:39 UTC#8
think pioneer will be able to fix it or should I just start shopping for a new one?
Posted Aug 24, 2008 · 18:51 UTC#9
Yes Pioneer can fix it.
Posted Aug 24, 2008 · 20:13 UTC#10
Yes.
Yes for which choice? :lol: Pioneer should be able to but it's going to cost $200
Posted Oct 02, 2008 · 07:04 UTC#11
hey would you be willing to sell you d3 to me and everything with it
