Broken mute wire
By aaronmakey · Aug 27, 2008in General💬 6 posts👁️ 970 views
Posted Aug 27, 2008 · 00:12 UTC#1
Hi...My bypass recently stoppend working and I realized it was because the head of the mute wire is almost comletely snapped...the break is too close to the end to tie the wires together. Do you have any idea for what I should do?
Posted Aug 27, 2008 · 00:25 UTC#2
The best thing to do is buy a new harness.
Posted Aug 27, 2008 · 01:24 UTC#3
pm me your address and i will mail you a new wire with the clip that fits into that plug, it's a d3?
Posted Sep 01, 2008 · 01:58 UTC#4
mine did the same thing... but we stripped the wire and stuck it back in there and taped it to another one next to it... its been fine for over a month now... because that wire just gets grounded... (correct me if I'm wrong...)
Posted Sep 01, 2008 · 03:20 UTC#5
Wires are wires...if there are any other wires in the harness that you're not using, you can use that one in place of the mute wire. As long as it's in the same spot and grounded it will work.
Posted Sep 01, 2008 · 04:10 UTC#6
Also, if you have small instruments, you could pry open the crimp on the pin and then put the pin on a new piece of wire.
