cant read install disc
By citadel · Sep 01, 2006in Problems/Troubleshooting💬 10 posts👁️ 1,894 views
Posted Sep 01, 2006 · 04:53 UTC#1
I just hooked up my AVIC D1 in a toyota landcrusier 1997.
It powers up but when I insert the nav disk, it does read it. Say something like disk read error...?
Posted Sep 01, 2006 · 10:52 UTC#2
Did you open the unit all the way and use the lower slot ? Try the other nav disc to make sure its not the disc ?
Posted Sep 01, 2006 · 12:26 UTC#3
YEs make sure you hold the eject button for at least 1 second and load the dvd disc into the lower slot.
Posted Sep 01, 2006 · 13:17 UTC#4
I'm dumb... that fixed it!
Posted Sep 01, 2006 · 14:21 UTC#5
Great !, Welcome to the forum and good luck with your unit
Posted Sep 12, 2006 · 23:40 UTC#6
I really do have this problem I just bought a D1 installed it and it tells me to insert the correct disc. I installed it in the lower DVD slot, tried east and west discs. I have version 1.2. I did the reset.
Any suggestions?
Posted Jan 20, 2007 · 23:32 UTC#7
I have the same exact problem. Seems like an on-going problem with these and the NAV disks not loading properly.
Posted Jan 21, 2007 · 00:45 UTC#8
are these backups ?
Posted Mar 13, 2007 · 19:42 UTC#9
I have this same problem too. I sent it to Pioneer TWICE to fix the problem and it's happening again.
Posted Mar 13, 2007 · 21:00 UTC#10
would probably ask pioneer whats up if your sending it back that many times.. dont you think?
