whenever i turn off the car, and start it back up the song or video doesnt start off from where it was when i turned off the car. and the eq keeps ressting everytime too. help anybodyyy?
Posted Aug 28, 2008 · 02:04 UTC#1
I would question the install. One of the two 12v wires needs to always be hot(red not yellow). Otherwise, and just like any other head unit, will lose it's memory.
the red acc wire?
The red wire from the unit is switched power which turns on and off with the ignition. The yellow should be connection to constant power which does not ever get shut off. The yellow wire powers your backup battery and supplies all the current for the unit when it's powered up. The red wire turning on and off is just a signal to "boot up the unit".
If the yellow wire and red wire are hooked to the same wire which turns on and off with the key, that will cause this problem you describe.
thank you ducatiboy! i got it to work. thanks!
