Ok, I am installing the F90BT in an '02 Altima. I have been trying to do this for the past 2 Days.
The First Headunit I got was dead out of the Box. The RCA Outputs were shot, and gave a sharp Popping & Snapping sound every 5 Seconds or so. So I took it back today and got a new Headunit.
The Second one worked perfect at first. I had it hooked up unmounted in the Dash (I was just holding it in my Hand, and used one of the Screw Holes for the OEM Mounting Bracket for the Ground, because Nissan OEM Radio's Ground out through the Radio Chassis, there is no OEM Ground Wire) with no Accessories hooked up to it (no Nav Antenna, No Radio Antenna, No iPod Cable) the only External thing hooked up to it was the Highs Amp. I started the Car and the Headunit powered on fine, no Alternator Whine, no Popping, everything was perfect, played a few songs on a CD and it was all good.
You would think I was done right? Ready to mount it in the Dash, connect all the Accessories and such and send the Customer away.
So then I connect the Nav Antenna, Radio Antenna, iPod Cable, tuck everything nice and neat inside the Dash, close it all back up and start the Car to back it out. Now I get a HORRENDOUS Alternator Whine / Squealing Sound, and the Headunit won't turn off when I turn the Key off, I had to undo the Ground for it to turn off.
I undid all the External Connections (Radio & Nav Antenna, iPod Cable), basically back to where I was in the beginning holding the Headunit in my Hand, and it working perfectly. So I start the Car and the Whine & Squealing is still there, but I can hear the Music.
What could possibly be wrong?
I am about to rip my Hair out with this Car. This is the most annoying Car / Customer I have ever had. I have seriously been working on this Car for the past 6 Months. They keep switching Equipment up, Blowing Speakers and Amps, ect...
