External Microphone Not Working???
By knecoli22 · Aug 28, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,350 views
Posted Aug 28, 2008 · 18:54 UTC#1
So I have the F90BT hooked up and am attempting to make a bluetooth call via my Blackberry Curve. I am able to pair the Blackberry and make the call but the person on the other end cannot hear me. I thought possibly a BT issue with BB Curve . . . However . . .
When I attempt to use the voice features, the little devil lady does not appear to hear me either. I double checked the external mic connection and it is plugged in, but does not appear to be receiving audio. The mic is mounted about 10 inches in front of my head on the visor.
Is there any way to test the external mic through the head unit??? I looked through the manual and the forums but did not see any such feature. Also, I assume the internal mic is disabled if an external unit is connected?
Thanks in advance!
The unit looks great in my recently dremelled 2003 F250 Dash!!
Posted Aug 28, 2008 · 19:20 UTC#2
and you're 100% positive its in the right jack? theres 2 identical plug-ins, one is for the mic ones for the steering wheel controls
Posted Aug 28, 2008 · 19:22 UTC#3
Whoa, talk about a rats nest!
+1 on the steering wheel control plug, lots of us have made that same mistake. :)
Posted Aug 28, 2008 · 20:21 UTC#4
yeah man, clean that shit up a little.... zip ties are pretty cheap nowadays....
Posted Aug 29, 2008 · 01:25 UTC#5
Haha
Down guys . . . its clean now! That was during the trial run to make sure the h/u powered on and was functional.
I pulled the dash off and checked (for the second time) that the mic is in the correct plug, and it is. The wired remote input is closer towards the bottom of the head unit. The microphone input is ridiculously close to the bus input.
Its in the right input . . .
No way to test it?
Posted Aug 29, 2008 · 01:57 UTC#6
Check the wire to make sure it isn't cut anywhere.
