Zoom in/out softkeys?
By mizifreak · Aug 30, 2008in Hacks/Mods💬 11 posts👁️ 2,238 views
Posted Aug 30, 2008 · 19:20 UTC#1
anyone thinks there's a way to create zoom in/out soft keys?
Posted Aug 30, 2008 · 20:36 UTC#2
Why would you need to when the volume button does it as well? Seems kinda redundant.
Posted Aug 31, 2008 · 02:54 UTC#3
I personallly don't like the feel of that dial...I know it is reduntant though just wondering if anyone came across that ideag
Posted Aug 31, 2008 · 16:35 UTC#4
If members have found a way to add a delete route button onto the map screen, then yes you can add zoom in/out soft keys...it's just a matter of finding the scripts and adding and editing them in a way that your new button will do just that.
Posted Aug 31, 2008 · 17:13 UTC#5
There are references to the zoom functions, but I'm not sure if they're active or not. I'm in the process of re-skinning my unit, and have been playing around with a new paradigm for how zoom is displayed and controlled, so I'll let you know if I find something that works.
Posted Sep 02, 2008 · 00:28 UTC#6
It's not the easiest thing to do, but when in map mode you can drag your finger across the scale for the zoom level to zoom in and out. They are kind of thin, so it doesn't work well with fat fingers, but the function is there on the touch screen.
Posted Sep 02, 2008 · 03:55 UTC#7
Dumb question, when on the map screen, my volume control doesn't control my zoom. It is controlling my ipod, so songs change and turning it controls my volume.
So how do you use it for zooming in?
Posted Sep 02, 2008 · 03:58 UTC#8
Push up or down on the knob. :D
Posted Sep 02, 2008 · 04:00 UTC#9
I have tried that too. Unresponsive in 2D or 3D. Does the sound but no action is taken. And that was tried 20 minutes into a drive so everything should have been loaded up.
Posted Sep 02, 2008 · 04:03 UTC#10
Tilt the volume knob up to zoom in, tilt it down to zoom out.
Tilting it left and right will move to the next or previous track, on the iPod or CD.
As far as putting soft zoom buttons on the screen, it is probably possible. It would take some searching though - it's easy to add buttons or other visual elements, the trick is making them do something useful. You could search all the script files in data.zip to find something that controls the zoom level; it would be in
I haven't noticed any zoom scripts in my exploration but I haven't been specifically looking for them.
Posted Sep 07, 2008 · 03:59 UTC#11
I think I found the controls for soft buttons to zoom in and out. I have not tested this, but I found these in the place_800_480.ui file:
What you can see is the onClick command starts the zoom in/out process and the onRelease command stops the zoom in/out process. The function START_STOP_ZOOM has two binary arguments. The second one is 0 to stop and 1 to start, and the first one is 0 to zoom in and 1 to zoom out.
You can take this code and stick it in your navigatemap_800_480.ui file, change the bmps if you want to make your own, or use text instead of graphic buttons.
Cheers!
