Blackberry 8830 - Keeping Bluetooth connected
By JH315 · Sep 01, 2008in Problems/Troubleshooting💬 14 posts👁️ 2,820 views
Posted Sep 01, 2008 · 20:02 UTC#1
Anyone have a step by step on how to keep this connected to the 700BT, or am I flat out screwed until I change phones?
I've seen the other posts, but everyone seems to have a different way, and they're inconsistent. Anyone have a tried and true, step by step.
Thanks in advance
Posted Sep 02, 2008 · 22:41 UTC#2
Thanks in advance
So you get it connected and it disconnects? Or you can't pair it at all? Let's say you get it connected and it quits, go into the "Properties" of the selected bluetooth device on your BB, mine is "Pioneer Nav". Now be sure you have "Trusted" set to yes. you can leave Encryption on, also when you initailly connect , you have a choice to reconnect and not ask you again, make a choice there.
Now maybe it connects and then disconnects, check your address book and see if you have a bunch of duplicate entries, or maybe you have more than 300. I think the limit of entries is 300, you'll have to check on that.
Other than that the instructions in the manual are pretty much right on.
Posted Sep 03, 2008 · 00:42 UTC#3
I wish it was that easy, its not. I will connect fine...and then randomly it will disconnect for 10-15 seconds then reconnect for a while, then wash rinse and repeat. Luckily, it does stay on for a good 15-20 minutes at a time.
Posted Sep 04, 2008 · 03:49 UTC#4
YEa... unfortunally my 8830 did the same thing. Btu my curve .. my chocolate worked alot better!
Posted Oct 21, 2008 · 02:39 UTC#5
yup my Sprint BB 8830 has the same problem..Anyone find a fix yet?
Posted Oct 21, 2008 · 03:27 UTC#6
had that problem with my curve... connect to the headunit via the bluetooth setup menu in the phone... works like a champ that way
if i connect thru the deck, it disconnects constantly...
Posted Oct 21, 2008 · 05:09 UTC#7
Cool i'll try that later.. Thanks
Posted Oct 23, 2008 · 09:30 UTC#8
Tried it and didn't work.. :( anybody else have suggestions?
Posted Oct 23, 2008 · 19:52 UTC#9
Nothing works...they keep saying the new updates fixes things with BB phones. I am actually pretty confident it will. Hang tight.
Posted Oct 25, 2008 · 20:12 UTC#10
I just got my radio and have the same problem. I keeps losing the connection after about 10 -15 minutes. I called Pioneer CS and they told me to go to phonescoop.com and download some software, they didn't know what it was called! But the pioneer CS said that BB's bluetooth is different and will not work. as well as any windows phones.
I am thinking about forwarding my calls to a phone that will work but I don't really want to pay 10 cents per min.
Posted Nov 19, 2008 · 14:19 UTC#11
On some other posts I have found a reccomendation that I tried and it worked on my 8130 and the wife's Curve. The directions are as follows:
1. Go into your address book and assign a category to all contacts of either Business or personal.
2. On your blackberry Goto Options --> Bluetooth --> Optionsand change Address Book Transfer: to Selected categories only and change Categories: by selecting Business and Personal.
3. Save changes
This works great and I no longer disconnect. Step 1 appears only to be necessary to transfer your contacts. Just doing steps 2 and 3 will allow you to stop disconnecting. Good luck all I hope this helps you as much as it has for me.
Posted Nov 19, 2008 · 16:15 UTC#12
In your step #1. Do you mean the address book in my outlook? Not sure which address book you mean.
thanks
3. Save changes
Posted Nov 21, 2008 · 15:45 UTC#13
I was referring to the address book(Contacts) on my blackberry. When you edit a contact one of the fields available is categories down below birthday and anniversary. I don't use outlook so I'm not sure if that is a field you can transfer from outlook. Possibly an outlook user can provide some insight. Hope that helps clarify.
Posted Nov 21, 2008 · 16:39 UTC#14
thanks
I tried it in Outlook and it seemed to work.
THANKS for your help
