Hey, I bought a 90bt and was just wondering if I should take it back. I never installed it, but kind of wanted to buy a kenwood dnx8120. Will I be happy with the pioneer? What do some of you guys think of this unit. Hoping to help make up my mind if I should just take it back.
Just bought a AVIC-F90BT. Should I keep it???
It depends on what YOU want, not what we think you should do. After Pioneer dropped the ball on the F-Series, this forum became divided 50-50 between the F and the DNX so you'll never get the fulfilling answer you want from just a handful of members. The DNX was recalled within 1 month of its release, but no unfixed issues have been noted.. But the F series came a long way IMHO. Despite all the bugs that it came with upon its release, only a couple remain. Those are the boot-up time, some BT connection issues depending on your phone (which they are releasing another update, strictly for the BT problems) and north only on 2D mode. I'm sure there are other little quirks that irritate other owners, but those are the 3 that everyone still encounters. The F series is also very customizable as far as changing the UI's and map options and such. TBH I think you should research what the F Series is capable of, and what it lacks before making your decision.
NOTE: EDITED TO CHANGE INFORMATION --Thanks Jet!!
The DNX never had a problem from Day 1 of its release, .
They were recalled for issues after the first month. You can also expect the same BT issues between the two of them. Both have the parrot chipset. Same issues with not being able to charge iPhones and the touch
The Kenwood is a little more difficult to use, with no way of changing the illumination color to match you current dash lighting. F- series also has MSN, where as kenwood has nav traffic with a very large antenna "hockey puck".
The DNX does have a dual zone if you have more than one monitor.
The DNX series also does not have a great website like this one, which is kind of a curse to pioneer since people have a place to gripe about it. Kenwood has a good customer service were all you get is a shoulder to cry on.
I still wish I had not bought mine, so I can't recommend you keep it.
But that's me, some people here really like theirs.
ive heard that the newer models are flawless plus the garmin nav is amazing.
like the dnx5120bt...
my own observation is that the Atlas map in f-series is weaker than the kenwood units maps the kenwood maps are more user friendly with direct access to points of interests verses all loaded in the poi of pioneer units
This past weekend I installed a 900 into my Toyota Highlander. I only have minor gripes about it.
- long boot up time
- 2d map behavior
Other than this it works great. I haven't tried an I-pod (nor probably will I), rear view camera, satellite radio/hd radio at this point in time. I want to play around with large USB drives next.
Thanks for all the info. I just have to try and find my speed senor wire to hook it up on my 06 dodge ram. I seen the post on where its located i guess I should try and install it, and try it out. The dealer gave me a little time to try it out because it was the first one they sold. Plus I like the 5 volt preout. I know the kenwood has the same but is more pricey. I also like the turn volume control rather then a push button volume, because I have no steering wheel controls. I also, looked at the alpine 505. The price was really good on it but by the time you add the black bird its about the same price.
yes the 5120 is bad ass
... Plus I like the 5 volt preout. I know the kenwood has the same but is more pricey. ...
I just added an amp to my 900. I do have lots of hiss when I set the amplifier gain where I would like it. The 900 has the lower voltage preout, so you should have less hiss than with my setup.
... Plus I like the 5 volt preout. I know the kenwood has the same but is more pricey. ...I just added an amp to my 900. I do have lots of hiss when I set the amplifier gain where I would like it. The 900 has the lower voltage preout, so you should have less hiss than with my setup.
More voltage normally means less hiss... not the reverse.
I was about to pull my F90bt, which was installed about 2 weeks ago, and put my "old" Panasonic Strada back in.
My god, The Navigation fuxking suck, cant find a place by Address at all, but I found it in POI, worst thing is that I have to "page down" one by one before I can find the place, I copied the address as said on the POI (which is almost the same as mine) , and enter it into the address ... nope, cannot be found. WHAT THE FUXK !
Unless they fix these bullshit issue (this navigation and others), stay away from the F-series !
I regret buying mine now after owning it for a couple of weeks and experiencing the slow bootup, crashes when using USB and the Nav is very unstable when it comes to voice, sometimes it will say the streets name sometimes it won't, and when I connect a USB device it distorts the audio coming from the Nav, its really low volume and on top of that, it makes the Nav voice stutter
I think I'm going to get the Alpine IVA-W505 and wait for the new nav module to come out that is going to allow an add-on nav without having to buy a Blackbird
but the only thing that works right is the CD/ iPod / FM
Sirius absolutely looks terrible on this unit compared to the XM interface and the Sirius interface in my OEM nav looked great, I actually had 3 lines of info:
Song
Artist
Remix info/ Song ad for another channel
I really miss my RockFord Fosgate system in my Lancer ![]()
I was looking at going to the 505, but still had the kenwood in mind. What and where can I find out about the other nav coming to the alpine 505. Thanks
http://www.alpine-usa.com/US-en/product ... gory=AV_HU
right now hat's all they have, I couldn't find any news on newer units.
Look I have been through many different radios and the new f series in my opinion is pretty damn good. I am not going to go through the all the options and such because I would be here an hour talking about it all. The D3 don't get me wrong was absolutely horrible after a year but the f series is 2000% better.
Took it back and good riddens. Don't recomend it at all. The load time is terrible. Then the ipod load time sucks as well. The voice command doesn't work most of the time. The nav is not very good. I'm so glad I got to take it back and got my money back. Also, the thing locked up on me screen became unusable. So, I had to turn it off and on again. I had it for about four days to try it out. I'm going to go with the alpine 505 or a kenwood system. Of corse that my opinion. I would have been pissed if I bought this unit without getting to try it and take it back. Maybe in a few years these units would be a bit better. Anyways its gone and time to move on. Just my 2 sents. Thanks to those who helped me on this unit.
I just took my F90BT back this weekend and got the DNX8120 to replace it. While the UI isnt as pretty as the Pioneer's, the unit works flawlessly. I don't have a single regret upgrading to the Kenwood.
I had a Z2 before the F and now the 8120. In my opinion, the 8120 is the overall best yet.
