Does anyone know if the RDP client is available in the CE install?
Remote Desktop
If it is included and is an executable I can't find it. If anyone that has access to the executable from another device that I can try and can post it, I would really appreciate it.
TIA,
RJ
sure, but even when you will find a rdp client. you will need a way to connect to the head unit and since it doesn't have a network connection or modem etc why do you want to run rdp on the head unit?
or did you found a way to remotely access the head unit
because that should be ![]()
I was thinking of experimenting with connecting to a carpc from this unit via RDP. The MP3 and video playback of the F series is very limited compared to a carpc but the fit and finish of the F series is a lot better than most carpcs. I was planning on trying to connect via bluetooth or possibly a usb ethernet adapter.
