No GPS signal, with new antenna, also no vehicle dynamics
By boosted_dc2 · Sep 02, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,334 views
Posted Sep 02, 2008 · 19:49 UTC#1
I dont know what is up. but my n1 that came with my car had no antenna, or disc. i bought a new original disc, and a new antenna. in the status tab, my VSS shows signal, the GPS antenna says OK, but never shows any signal. everything else works, but my navigation doesnt work obviously. i tried a reset, and a reset with holding the eject button, still nothing. It says initializing sensor, but no bars ever fill, and no turns or anything work. any help????
Posted Sep 02, 2008 · 21:00 UTC#2
I had a similar problem with my N3 and found that the connector to the brain was loose at the head unit. Once it was plugged in properly, all was well.
regards
~Marc
Posted Sep 02, 2008 · 21:05 UTC#3
be sure to check all your connections and make sure that the unit is as flat as possible for the gyro sensors to work properly. If these are all perfect go drive around for about 5-10 minutes and take a figure 8 trip around your local streets. This will initialize the unit properly. If all these steps still result in a failed programming you should check with your local authorized delaer to talk about servicing the unit.
Posted Sep 03, 2008 · 01:15 UTC#4
do you think the antenna could he bad. It says ok but no satelites are lit up.
Posted Sep 03, 2008 · 01:23 UTC#5
Where is your antenna located?
Posted Sep 03, 2008 · 05:18 UTC#6
i have a civic hatchback, its on the roof, right in front of the rear hatch.
i just dont understand why it says gps antenna OK, but no signal.
Landon
