Z1 unit upgrade to Z3 unit question
By 1sicka4 · Sep 04, 2008in General💬 2 posts👁️ 871 views
Posted Sep 04, 2008 · 00:54 UTC#1
Hello, I had a Z1 stolen. If I wanted to upgrade to the Z3 is everything plug and play? All the wires that were plugged into the Z1 are still there.
Also does anyone have a picture of the backside of the Z1 and Z3?
Will I need to add additional wiring or remove additional wiring?
Posted Sep 04, 2008 · 20:20 UTC#2
All wiring is the same, the Z1 and Z3 are 100% hardware identical, the only difference is slight upgrade in software.
If you had an old Z1 with the old headlight flash type bypass, you'll need to update to the newer 2-wire bypass.
