No light green wire on power connector? v.2 wire bypass
By DruMMinStUd06 · Sep 04, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,010 views
Posted Sep 04, 2008 · 12:55 UTC#1
I've been trying to do the 2 wire bypass for the last couple of days now using Steve's method (http://www.sminntech.com/z1flash.html#newbypass).
The issue I'm running into is that there is no light green wire on my power connector.
The colors on the connector are as follows: the 4 pairs of speaker wires with their corresponding colors with a black stripe (white, gray, green, violet), as well as blue, pink, no pin (empty), black, and violet/white, red, light orange/white, and yellow. I know from the manual that the pink is the speed signal wire and the violet/white is the reverse gear signal input.
I know the wire is hooked up somehow because the Z1 knows when my parking brake is engaged or not.
My question is: which one is the light green "supposed" to be? Because apparently there's something wrong with mine, and there is no light green. If someone could post a picture of their power connector off their Z1 so I could compare to mine, I'd greatly appreciate it.
Posted Sep 09, 2008 · 15:18 UTC#2
I called Pioneer and they said they don't have pin diagrams. They did give me the following information regarding each wire:
*Doesn't list speaker wires
red - ignition
yellow - constant
light orange/white - ILL
black - ground
blue/white - accessory or system control (amps)
pink - speed signal
yellow/black - accessory mute (cell mute)
blue - antenna
light green - handbrake
purple/white - reverse gear
Seems to me he just read out of the manual. Whatever. Here's what I have in my power harness:
blue
pink
*empty*
black
violet/white
red
light orange/white
yellow
I would imagine that its the empty pin, but the Z1 knows when my parking brake is up or not...so I'm not really sure what to do other then pull my car apart and follow the wire from the brake.
Posted Sep 09, 2008 · 17:30 UTC#3
Did you try looking at the wiring diagram in the manual? IIRC, it should show which pin the green wire is....if there's a different color wire in that pin, thats your new color...if there isnt any, you can use a wire thats useless to you and put it in there, then use that.
Posted Sep 09, 2008 · 18:17 UTC#4
the wiring diagram in the manual doesn't show which pin it goes to...
Posted Sep 09, 2008 · 23:55 UTC#5
It's supposed to be between pink and purple/black on the top row.
