Reverse Wire Necessary?
By kg_jettaIV · Sep 05, 2008in General💬 11 posts👁️ 1,622 views
Posted Sep 05, 2008 · 01:18 UTC#1
I'm installing my F700 tomorrow and just wanted to know if the reverse wire is necessary or not. I'm not hooking up a reverse camera and if I do down the road I can always connect it in then. The biggest question I have is whether the reverse wire has anything to do with navigation or if it only is used to turn on the rearview camera. Thanks.
Posted Sep 05, 2008 · 01:23 UTC#2
it tells the unit that you are going in reverse so the arrow will go backwards instead of forward. so i would say yes it is important
Posted Sep 05, 2008 · 01:26 UTC#3
That's what I wasn't sure of. Can anyone else confirm this, and I'm not sure how terribly important that is.
Posted Sep 05, 2008 · 01:42 UTC#4
i didnt have mine hooked up for about a month and when i parked in the garage it would always go forward when i was in reverse and take about a minute to get back on track. this was always a headache when setting a route at home. it only takes a minute to hook up so why not just do it.
Posted Sep 06, 2008 · 02:36 UTC#5
I never bothered hooking it up. Doesn't really matter unless your looking at the gps while in reverse.
Posted Sep 06, 2008 · 02:44 UTC#6
Simple solution. Don't hook them up. Use the nav for a while, and if it's not accurate enough for your liking, pull the radio out and hook them up.
Posted Sep 06, 2008 · 02:54 UTC#7
I'll go simpler than that. Just hook it up!!
Posted Sep 06, 2008 · 22:55 UTC#8
Well I hooked it up. It was a pain in the ass to get to, but oh well. Thanks for the replies.
Posted Sep 07, 2008 · 04:58 UTC#9
Is your reverse hooked up? It has a play in your nav. as well.
Posted Sep 07, 2008 · 06:00 UTC#10
THANK YOU just hook it up guys it really takes two seconds
Posted Sep 07, 2008 · 06:06 UTC#11
YOU"RE WELCOME ! :lol:
