AVIC D2 not loading nav disk
By fiberglasslvr · Sep 05, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,126 views
Posted Sep 05, 2008 · 05:24 UTC#1
My AVIC D2 does not load the nav disk when i power it on it says loading pioneer navigation but then goes to please insert appropriate disk, so then i eject the disk and reinsert it and it does the same thing. i did reset it from the front but it did the same thing.
please any help would be appreciated
thanks in advance.
Posted Sep 05, 2008 · 06:54 UTC#2
Is it an original disk or a copy?
Posted Sep 06, 2008 · 03:34 UTC#3
it is an original
Posted Sep 06, 2008 · 08:23 UTC#4
Did this just happen suddenly, or did you buy it used and it was already like that?
If the latter, my guess would be someone used a newer disc in it and you'll need to go through the downgrade procedure to use the original disc. I believe a search should find the downgrade procedure.
