2003 Pathfinder - Issues Replacing NAVSYS910DVD with F900BT
By damorris25 · Sep 06, 2008in General💬 7 posts👁️ 1,442 views
Posted Sep 06, 2008 · 16:00 UTC#1
Ran in to an issue, hoping someone can help me. I have a 2003 Pathfinder LE in which I had a NAVSYS910DVD:
http://www.pioneerelectronics.com/PUSA/ ... -SYS910DVD
This is one of the first gen type units where the Navigation unit was separate. I had it professionally installed by a shop about 5 years ago. Recently, the Nav unit portion completely died on me so I wanted to replace it with an F series. I took it to Best Buy to have it installed and have hit a snag. They are telling me that the new F series can't be mounted to the dash without the original Double-DIN style brackets that came with the factory stereo. I no longer have the original stereo and when I contacted the Nissan Dealer about new brackets they said they don't sell just the brackets.
I know I could go with one of the newer Pioneer units that are single DIN in dash Nav units but I really don't want to do that. On the positive side, the in dash portion of my setup is still working so I have audio, just no navigation.
Has anyone on here had any experience with something like this? Any thoughts? If I took it back to the original custom shop where I had the original work done would I get a different story or would they at least be able to work around it?
Thanks in advance for anyone with some advice.
Posted Sep 06, 2008 · 16:27 UTC#2
why is that thing so much :shock:
Posted Sep 06, 2008 · 16:31 UTC#3
check with crutchfield, they can probably sell you what you need.
Posted Sep 06, 2008 · 17:00 UTC#4
You need the factory brackets. Call a different dealer, they are available.
Othwerwise, buy a factory deck off ebay.
Posted Sep 06, 2008 · 20:02 UTC#5
Thanks for the replies all. I found another site where someone said that the parts are separate for right and left and you should be able to order them. He mentioned part numbers 280394w400/280384w400. I'll see if these are what I need. In the meantime, I got my money back on the F900BT till I figure out what I want to do - my audio is at least working so worst case I'm just left without Nav in my car.
Anyways, thanks again for the replies.
djhuab - it was so expensive because that was one of the first units of it's kind. I didn't pay anywhere near the 3500 retail. I found it on pricegrabber 5 years ago for 1900 and then 150 for the XM unit so not too much more than retail for the newer units.
Posted Sep 12, 2008 · 18:23 UTC#7
Just in case anyone else stumbles across this site with the same issue...
Every shop I talked to said I would need the original OEM stereo brackets. I went to the Nissan dealer and had to special order parts 28038-4W310 and 28039-4W310 for the brackets, as well as 08510-51612 which are the screws.
I'm getting my F90BT installed in the next week or two after I get the parts.
Thanks to all for the replies. My next issue after that will be the dash opening but I'll cross that bridge when I get there...
