Hi,
I pm you because you are the best and I wanted to make sure I have your input. From what you said the Z series never needed a toggle switch but the installer did put one in my car. Basically, when it`s on I can use the greyed buttons when i'm going under 15 mph. When it`s off, I can't. I was told that it replaces the fact that I have to put the hand brake? Should I should take it off or replace it by something else? Does the 2-wire bypass solve all this?
Thanks,
Jonas
Why would you ever turn the toggle switch off, then?
Do the 2-wire bypass, as we've preached all over this forum.
