Numerical Zoom Scale?
By skicrave · Sep 08, 2008in Hacks/Mods💬 7 posts👁️ 1,803 views
Posted Sep 08, 2008 · 20:51 UTC#1
Has anyone found a variable that will output the zoom scale in plane text? I would like to display the current zoom setting as 1/2 mile, 1/4 mile, etc rather than having the zoom bar.
Anyone have any ideas?
Posted Sep 08, 2008 · 22:25 UTC#2
I would love this function too - personally I find it much easier to read and understand, than the zoom bar (which I found small and hard to read).
Posted Sep 08, 2008 · 23:24 UTC#3
I'll keep searching, but so far I haven't seen anything that looks promising in the UI files, or in any other iGo skins.
Posted Sep 09, 2008 · 02:18 UTC#4
I've been looking through the executable and found two possibilities. I'll test them in the morning.
There is a "ZOOM" command/variable, which I'm going to try accessing as map.ZOOM (based on the zoombar being map.ZOOMCONTROL).
There is also a "nZoomLevel" variable. I'll see if either of them produce any output. It's possible that even if we find a variable, it won't give us a friendly output, just a relative integer (like the heading does). Although that might be good enough, if you don't need the actual scale, just a relative number.
Either way I'll let you know what I find.
Posted Sep 09, 2008 · 13:13 UTC#5
Well I tried those variables this morning, and it didn't pitch any errors, but it didn't display anything either.
This means that either the variables I guessed at don't actually exist, or that the textmodel I used is incorrect for the type of data in the variables.
I'll test again with different textmodels and see if anything turns up. I'm sure there must be a way to display something, it's just a matter of finding the right variable and matching textmodel.
Cheers!
Posted Sep 09, 2008 · 14:03 UTC#6
Thanks for the update Stephanie, I'll keep you posted on my success as well.
Posted Sep 11, 2008 · 16:24 UTC#7
I'm going to give up on this one.. I've tried every variable I can think of, every combination of textmodel I can think of, and nothing comes up at all.
At this stage, I don't think there is a way to access the data. I know the data is in there, of course, but there doesn't seem to be a way to display it other than the zoombar.
Of all the variables I tried, I thought these had the most potential:
map.zoom_level_in_map
map.zoom_level_in_navigate
map.zoomlevel
Unfortunately none of the textmodels revealed any data for me, nor any of the text methods. I have a feeling that the data is in some format that there's no text method for - the zoom is a very 'smooth' zoom, instead of large discrete steps, so it's probably a hex or binary thing...like 8 bits or 16 bits or something along those lines.
Thinking of the way the zoombar reacted, it didn't just change text headings over a fixed-width scale, but the scale indicators changed size and the text headings moved around accordingly - so perhaps the best we could have hoped for would be a hex readout, like 1A or 4F or whatever...
So I'm giving up - conceding defeat on this one. ;) Same as with the car heading in degrees - for now I think it simply doesn't exist in there in a format we can use.
edited to add:
If I am correct, this is something that the iGo programmers would have to add - either a textmodel_hex model, or add a full_text method to the appropriate variable. Ditto for car heading, we have navigate.car_heading but the programmers would have to add a .full_text method that would perform the (simple) maths to turn the integer into a degrees readout.
