power antenna
By jstevens · Sep 08, 2008in General💬 3 posts👁️ 588 views
Posted Sep 08, 2008 · 23:52 UTC#1
I want to install a power antenna to use with the AM/FM installed with my D3, and I want to be able to use the D3 function which allows to toggle between electric power & FM/AM selection to power up the antenna. Do I need a power antenna with specific properties and are there any specific connections to the D3?
Posted Sep 09, 2008 · 01:23 UTC#2
all aftermarket power antennas have a 12+ constant power wire, a ground wire and a activation wire that you will hook up to the d3. thats all you need to do!
Posted Sep 09, 2008 · 01:26 UTC#3
Thanks for the info
