Has anyone found where the info for the current AV source on the map screen is contained? I'd like to move things around a little and change the images that are used for the various sources (iPod, XM, Radio, etc.).
AV Source on Map Screen
The images are in the Images.Res file in My Flash Drive\APL
The program that displays the information is not part of the iGo software. I believe this is the command that launches it:
EXEC "other.pioneer.postmessage" "AV" "WM_APP_AV_IGOMAP" 1
That line is in data.zip\ui_pioneer\common\ui\navigatemap.ui
As far as I have seen, there's no way to move it around, you can just suppress it by commenting out that line.
Hmm, well that changes things quite a bit. Now the question is am I willing to give up that info completely...
Thanks once again Stephanie.
I checked where this is called, and every state that displays the AV source, in none of the UI layers it uses is there any reference to AV pictures. I have a feeling that even if you put something in the position where the AV button is, AV will come up on top of it because it is drawn through a windows message to an external program, not as anything inside iGO...
