iPOD shows up but no sound
By cognizantnamja · Sep 10, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,183 views
Posted Sep 10, 2008 · 03:10 UTC#1
So I installed the 700BT and hooked up the iPOD cable (RCA) in the process. Plugged into the USB cable as well. My sister says that the song titles and all that show up on screen but there's no sound. I made sure to tape the RCA cables together so that they don't fall out. I know the system is working as it plays the radio and CDs just fine. Any clues as to why it's doing this?
Posted Sep 10, 2008 · 03:17 UTC#2
a lotta times you just gotta pull the ipod out and start over. just disconnect it and plug it back in. this has happened to me before in my 900. did you switch AV1 to "iPod"? that's another common mistake
Posted Sep 10, 2008 · 03:31 UTC#3
From the Menu Screen, hit Settings, then AV Settings, then set AV Input 1 to Ipod
Posted Sep 10, 2008 · 03:32 UTC#4
DEFINITELY your problem.
Posted Sep 10, 2008 · 03:51 UTC#5
Alright... I text'd my sis the instructions. Hopefully, this will solve the problem. Thanks, folks!
Posted Sep 12, 2008 · 19:17 UTC#6
Update... indeed, your suggestions solved the problem. Gracias!!
