If you use the in motion by-pass, grounding the mute / parking brake wires and changing the pin connection, do you still need to connect the speed input wire or is that by-passed as well since the unit things it is in park. Does that also apply to the reverse light connection. Is that not needed as well??
Posted Sep 10, 2008 · 21:49 UTC#1
