ARGHHHHH!!!! System Settings, phone, multiple buttons gray
By jcorso1111 · Sep 11, 2008in Problems/Troubleshooting💬 12 posts👁️ 1,353 views
Posted Sep 11, 2008 · 14:32 UTC#1
Cant use bluetooth, cant check firmware. No documentation other than PDF.
am i missing something
Posted Sep 11, 2008 · 14:46 UTC#2
Did you bypass it or connect it to your parking brake? Did you connect your phone?
Posted Sep 11, 2008 · 14:49 UTC#3
+1 One of those has to be done before you can access those menus.
Posted Sep 11, 2008 · 14:51 UTC#4
of course not!!! how do I bypass it!
Posted Sep 11, 2008 · 14:52 UTC#5
No need to shout.. Check the sticky's in the Hacks/mods section. The bypass is at the top.
Posted Sep 11, 2008 · 15:04 UTC#6
wasnt shouting, just excited that the unit wasnt fried!
Anyways, is the bypass wiring only, or does the speed mod in the end of that thread work to solve these issues.
Posted Sep 11, 2008 · 15:07 UTC#7
Ok, just that a bunch of !'s signifies shouting.
The bypass is just relocating the mute wire and grounding the mute/parking brake wires
Posted Sep 11, 2008 · 16:10 UTC#8
ok. The pic show the mute just fine, by grounding the mute and parking brake, what do you mean.
Posted Sep 11, 2008 · 16:10 UTC#9
Posted Sep 11, 2008 · 16:59 UTC#10
Attach the mute wire and parking brake wire to either the black ground wire on the radio.
Posted Sep 12, 2008 · 12:35 UTC#11
Hey there. I had the same issue. I also had the problem that it looks like the upgrade was not done to the unit. Do you have the blue dot on the unit and the box it came in?
If not that might be the problem as well.
Posted Sep 12, 2008 · 12:45 UTC#12
The update has nothing to do with blocked out features. His unit isn't bypassed.
