drober30 said:
I just checked and it reads OFF. I started the car and it immediately came up with that message.
That's really weird. If that's off, then it shouldn't come up with that message. You might want to reset the unit. There are 4 levels of resetting. You might want to try them all. Usually just the recessed button to the right of the eject button will get rid of that message... Unless they programmed and installed the TR7's wrong.
drober30 said:
I will call them and tell them I want your circuit installed. I will ask them if I buy it if they will put it in. I'm sure they will their real good guys.
My circuit is nothing magic. If you install and program the 2 TR7's correctly, they work the same. Just that with my circuit there is no programming and, I would like to think, an easier install.
drober30 said:
I have two vehicles so I will be ordering two circuits if they will.
Feel free to order some, but if you already have TR7's those should work, there is a sticky in this forum with how to install and program them.
drober30 said:
Another question: I had one installed in my 05 Trailblazer last week and the tech said he could not get the illumination to work because there was no 12v just a pulse or something like that. I thought I read that with your circuit it didn’t matter that it would work with these new pulse/canbus systems?
Well, pulse and canbus can mean different things. My circuit is smart enough to watch a "dimmer" signal and activate the Z1. The Dimmer wire is a pulsed 12V. It is 12V for 1/1000 second and then ground for 1/1000 of a second. Your dimmer knob will vary the time on and off to adjust the dimming of the interior lights. I tried to program my circuit to work of that signal and make 12V while it sees that signal.
Canbus is usually more of a command signal. When you turn your lights on the system sends out a "hey I turned on the lights" and then that's it till you turn off your lights and then it sends out a "hey, I turned off the lights" signal. My circuit and the Z1 won't work with this, we need at least something all the time when the lights are on.
There are canbus adapters out there, that will watch for these commands and send out a constant 12V output until it sees the "hey I turned off the lights" command. It's something to consider.
