I seem to be having an issue with my GPS all of a sudden. For some reason it will not track correctly a lot of the time and sometimes it will randomly work correctly.
So I went into the system settings and watched the GPS antenna screen. Most of the time it is only locked on 2 Sat. and often it just loses all Sat. and all signal. Is this most likely an issue with my antenna? Should I just buy another antenna?
Thanks in advance
