steering wheel maguel, cobalt
By jose · Sep 13, 2008in General💬 5 posts👁️ 1,166 views
Posted Sep 13, 2008 · 01:22 UTC#1
we have the maguel and everything for a 2007 chevy cobalt. i did everythign that the instructiongs said and it still doesnt work.
we put in a navigation pioneer 90bt in it. could the new nav. system be the reason why the steering controls are not workin?!?!?
Posted Sep 13, 2008 · 02:40 UTC#2
which module did you buy? and yes when you take out the OEM deck the steering wheel controls are useless until you buy a steering wheel adapter and hook it up properly
Posted Sep 16, 2008 · 22:01 UTC#3
ok thanx. we already used the steering wheel adapter and module (SWI-PS). we followed programed everything and the steering wheel controls are still not working. What now?
Posted Sep 25, 2008 · 17:55 UTC#4
you also need to make sure you supply a +12V to the steering controls as well.
I hooked mine up a long time ago so I am not exactly sure, but the instructions where a little fuzzy on that part.
The stock head unit supplies +10V to the the controls and if you follow the direction with the SWI-PS it leaves that part out. You need to find that +10V wire on the stock harness and hook up a +12 (you can't do +10 anymore without the stock headunit). Then you should be able to program it ok.
The stock system works (at least on my 2005) worked on a +10V reference and a series of resistors to tell the head unit the button you pushed based on volatge drop.
Posted Sep 27, 2008 · 19:03 UTC#5
we followed every instruction but they are still not working.
would the year matter in this case? because mine is a 07 ?
