VW Transporter / Caravelle? Actually most VW should do?
By lowbug · Sep 14, 2008in Vehicle Specific Wiring💬 2 posts👁️ 651 views
Posted Sep 14, 2008 · 21:07 UTC#1
Hi, I have the VSS working via a Canbus adpater but i'm after the reverse wire and the most important>> the ignition which stays live until the key is removed. I have temporaliy picked up a switched ignition at the headlamp switch but if you have to restart the car or sit waiting for your wife when shopping you have to leave the key on as the unit will switch off. Not ideal. :).
