The installer connected my z2 to my factory wiring harness with butt connectors (didn't use the aftermarket harness). Started experiencing speaker cut outs and decided to redo the wiring. Upon inspection I noticed the butt connectors were starting to get loose (wires were thinning).
I soldered the aftermarket harness in and was able to clean everything up. I did however leave 2 wires unconnected (had no clue where they went). Now the library play list wont play but everything else is working fine. Any help? I know this is vague but I would like to try and troubleshoot this before having to take apart the unit again. Thanks in advance ...
-Pete
