Display at night
By bhud · Sep 15, 2008in Hacks/Mods💬 7 posts👁️ 2,773 views
Posted Sep 15, 2008 · 18:57 UTC#1
Hi all,
AVIC d3BT
We have one fitted to a Porsche Boxster.
When the lights are switched on is there anything to be set so as the display darkens to night mode?
Thank you inadvance for your help.
bhud :?:
Posted Sep 15, 2008 · 19:03 UTC#2
Yes, you don't have the illumination lead connected. (orange wire)
Posted Sep 15, 2008 · 20:22 UTC#3
Hi all,
AVIC d3BT
bhud :?:
Do you mean an AVIC-D3 or a European AVIC-HD3BT ?
Because the HD3BT is not a "D-series" unit here in the US, it's a "Z series" unit. It's basically the European version of the AVIC-Z3
Posted Sep 15, 2008 · 20:46 UTC#4
In Europe, they did have an AVIC-D3BT. I think it was an AVIC-D3 and CD-BTB200 bundle.
http://caraudiosecurity.com/shop/produc ... /5821.html
I agree on the illumination lead not connected. Although I believe there is also a setting in Settings to set whether night mode inverts the map or not. I'd check there first since it's easier than pulling the stereo out to check the wiring.
Posted Sep 15, 2008 · 22:19 UTC#5
I believe it is set to change by default.
Posted Sep 16, 2008 · 05:19 UTC#6
Thanks folks will check the orange lead is connected
Posted Sep 19, 2008 · 03:58 UTC#7
I have DRL's, so any info you pass along when illumination wire is likely not connected....
Paul
