Everyone,
I exchanged a f90bt with al-eds. The new unit did not have the blue sticker on the box. It states that is was mfg in May 2008. How do I tell if the upgrade has been done?
Also I cannot get the phone to pair. I put it in discovery mode and yet it will not find the unit. I tried it like 3 times. Any ideas.
Also. I tried rebooting the system to see what would happen. Nothing new. The system setting/information is grayed out.
Also I cannot play video on the machine. It states that I must have the parking brake engaged. I had the bypass done. Double checked the wiring. The one that was supposed to be ground is spliced into the ground wire for the unit itself to the car. Any ideas.
Should i try doing the upgrade? Will it hurt the unit if it is already there.
When I hooked up the new unit it had the lagnuage selection but it was grayed out. The only button I could push is the ok button. Wha is that all about
