N2 questions please help
By nhn23 · Sep 16, 2008in General💬 2 posts👁️ 879 views
Posted Sep 16, 2008 · 23:54 UTC#1
what good does the Reverse Gear wire do and what does the Speed Sensor wire do? is there a point in connecting these wires?
Posted Sep 17, 2008 · 03:53 UTC#2
If you have a back-up camera installed, then the reverse wire will automatically turn it on when ever you select "Reverse" on your shift lever. If you don't have the camera I doubt you need the wire connected.
The speed sensor wire should be connected as it sends signals to the brain that will help the system initialize.
regards
~Marc
