Posted Sep 05, 2006 · 20:51 UTC#1
I just received a GEXP10XMT as a gift and I am interested in installing this unit in the trunk and then run the wire (s) to the AVIC-Z1 already installed. I want both the XM function and the traffic updates. To make this happen how many wires need to connect back to the AVIC-Z1? In the AVIC-Z1 install manual it shows you need an extension for one of the connections, but the diagram is a bit confusing as to how many connections are actually needed, since it shows other components that I don't have. I bought one extension cable, but the second cable with a blue connector in one end is not long enough to reach the dashboard from the trunk. Do I need this cable to connect? Is there an extension required for that cable also? It may be that I am missing how XM is setup back to the AVIC-Z1. Appreciate any help.
