Hi all
Need some help with music and also pictures.
First problem – I am trying to load some pics on to the Z3 (upgrade from Z2). The pics are for my phone, I have them on disk and when trying to load them I get a message that I need to create a folder. Does this mean that I have to take the drive out, connect to my PC and create a folder for the pics? I have all the connections to connect to my PC and the drive is also unlocked.
Second problem – I bought the steering wheel remote “PAC SWIPS†for my unit, also upgraded the remote from the 4 button to 6 button.. Everything works great except for one thing.. I set up the remote so that I can select the preset stations on XM and FM. Well when playing a music CD or even music from the hard drive, the same button used to select the presets will not move to the next track. The button does nothing. Do I need to set up the PAC unit so that it will scan or something. If I change that will I still be able to select the preset stations or will it just jump to the next available station on the radio?
One last thing – I only have 4 speakers in my car (06 Sonata), I would like to upgrade the speakers and put in a sub, there is a place already precut for the sub, however I don’t really want to buy an amp. Can I still connect the Z3 to the sub, how would I do that? Seems like I would need to use the RCA jacks for the sub but then would need an amp, is this correct or is there a way to use the speaker wires coming off the unit without using the RCA’s?
Any help would be greatly appreciated – thanks in advance.
