How to run an avic n2 update disk?????
By husa4342 · Sep 21, 2008in Problems/Troubleshooting💬 8 posts👁️ 2,745 views
Posted Sep 21, 2008 · 00:37 UTC#1
Ok after tons of problems I used the reset method with a n50 disk and now have my basic nav back, but years out of date. I tried popping in my n70 disk that I updated with before and I get checking disk, then nav kicks on and goes to insert correct disk. Is there some step I have to take to get the update disks to run and install? I remember last time I updated it went through a whole software update and changed the look of everything, but no luck on just putting in disk and resetting. any help would be great!
ty
Posted Oct 08, 2008 · 20:55 UTC#2
your doing it correctly but sometimes on my n2 i have to put the disc in shut off car and turn it back on then it will load correctly (only really have this problem with burnt discs)
Posted Oct 21, 2008 · 17:29 UTC#3
accually sounds like your dvd pickup lens is having troubles reading try runing a dvd lens cleaner in it then try it should run alot better
Posted Mar 09, 2009 · 22:43 UTC#4
anyone in the middle Tn area that has and can install update disc for a n2 ?
Posted Mar 10, 2009 · 05:35 UTC#5
You don't install anything, you buy the disk and stick it in
Posted Mar 18, 2009 · 15:16 UTC#6
just asking, from what i read on here there's more to it than just sticking it in.
Posted Mar 26, 2009 · 04:37 UTC#7
Nope, all you gotta do is stick it in, and it'll update automatically. If it's still not working definitely try a dvd lens cleaner!!! What version up-date disc are you using? If you don't have the 80-MT disc, you can get it from this dude on ebay. It's the cheapest I've seen on ebay and it's where I bought mine. Let us know if anything else comes up!
http://cgi.ebay.com/Pioneer-CNDV-80MT-East-or-West-Disc-New-and-tested_W0QQitemZ280325710145QQcmdZViewItemQQptZGPS_Maps_Software?hash=item280325710145&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted Apr 06, 2009 · 18:27 UTC#8
If anyone needs repair service, or a bypass to run the new software we can do it for a very affordable rate.
Check us out at www.turbotunes.com
-Steve
