my hack to remove those blue boxes and more
By bitman · Sep 22, 2008in Hacks/Mods💬 5 posts👁️ 2,727 views
Posted Sep 22, 2008 · 09:34 UTC#1
this is my hack i run on my f900bt at the moment.
please be sure to know what you are doing as i don't take any responsibility if you brick your box. i will not put my data.zip file here since in my opinion it isn't a good idea to just copy a data.zip file on your box.
i want to thank all on this board for directions, ideas & scripts.
this hack puts the box in full cockpit screen mode by default and only shows those blue boxes when you navigate. the compass is a button to cancel your route.
navigatemap_800_480.ui
; to use the compass button to cancel navigation route
; change the color of time printed on the screen
variable_def.ui
;hack to remove blue bars and other unused stuff from screen while not navigating. this will put the navigation in full cockpit screen by default
navigatemap.ui
;	map.ZOOMCONTROL_SHOW 1
map.ZOOMCONTROL_SHOW 0
; only needed if you want to keep secondary info on screen since this is disabled in fullscreen mode
; multi info box only on at navigation
have fun,
bt
Posted Sep 23, 2008 · 04:53 UTC#2
You are a God if this works.. I made all the changes.. will upload in the morning to see if it worked.
Posted Sep 23, 2008 · 08:02 UTC#3
well i found a small bug. in the info box (bottom left) the speed and time is missing. so i need to fix that. otherwise it works fine.
Posted Sep 23, 2008 · 17:51 UTC#4
I noticed that also while driving in... thought I had messed something up.
Posted Sep 28, 2008 · 14:05 UTC#5
sorry for the delay of coming back to this but i'm very busy on my work (worked 33 hours in one go this friday) so it will take me some (more) time to create a fix for this.
